TwinTurbo.NET: Nissan 300ZX forum - Pretty much the same as the front pads - once wheel
Subject Pretty much the same as the front pads - once wheel
Posted by jzack on August 17, 2013 at 11:16 PM
  This message has been viewed 130 times.
In Reply To changing rear brake pads 96tt posted by lbw46 on August 17, 2013 at 10:26 PM
Message is off, remove wire clip holding top and bottom slide pins in place, remove slide pins, remove spring plate, pull out pads, remove cap from brake reservoir, push pistons/retract them, insert new pads and put it all back together.
PS - Be sure to use brake grease on the slide pins too - makes sure the pads move freely. I clean everything up with spray can brake degreaser first including the pistons BEFORE retracting them (ie., no dirt/grim is pushed back inside of the piston dust boot). Clean up every surface that he brake pad touches when moving then re-grease those surface but of course, not the brake pad disc contact area....
FYI - Other cars sometimes have the parking brake as part the rear piston system (our Z does not). Those cars require the piston to be turned in order to get it to retract.
